Alert conditions settings more than 48h
Trying to set up a rule for alerting, and i need to check query conditions for 7 days, but in alert i can set up to 48h only. Is it possible to set up more range?
Can you show us the settings you are trying to apply?
Btw, my dev checked and did not see a limit to time range. You should not be limited in the number of hours back that you set the alert to check.
Seems to work for me to specify a week in the alert condition. I had to specify it in hours (168h) as days is not supported:
daniellee Thats[quote=“munch, post:1, topic:40235, full:true”]
[/quote]
Thats it, thanks!
