Alert folder deleted, but Alert still running,
Hallo All,
i deleted a Alert Folder , but i still receiving Firing notification.
i’m using Grafana V.9.3; InfluxDB
where can i find the deleted folder?
how can i find the deledet folder?
thank you
Hi @kabs , deleting a folder that has an alert associated with it fails with a yellow warning and it should not delete the alerts nor the folder.
Could you please share the detailed steps for reproducing your issue? thank you!
Just adding that I also have the same issue which I posted here
how did you delete this folder? from the ui?
That’s correct @soniaaguilar
Could you please reproduce steps and share screenshots , in particular when you are deleting the folder that contains alert rules? Because, as I said before, if the folder that has an alert associated with it fails with a yellow warning and it should not delete the alerts nor the folder.
Hi @soniaaguilar,
It’s been awhile since I did the cleanup but the alarm I deleted via UI would not be in an alerting state as it relates to disk space and only now is the limit being hit.
So it’s pretty much:
  1. Locate alarm in alerting UI
  2. Delete alarm (not in an alert state)
  3. Wait until threshold is breached to alert
Note I cannot find the alarm via the UI, hitting api/v1/provisioning/alert-rules/IkZWM1M4z does give back the alert configuration, sending a DELETE does indeed remove it.
