Alert going to OK state when it sould not
  • Grafana v7.2.0 (efe4941ee3)
    My alert behaviour is not normal. OK state when it should not be OK
  • What happened?
    I have elastic search query which is looking for data.
    if avg is more than 1 is should be alert.
    Why it goes to alert state so many times and why it goes to OK state when it is clear that is still an issue?
    In the raw data there is no issue.
Can I have at least some suggestions ?
Data is from elastic search…
