Alert no firing
I’m having trouble firing an alert I set up : my conditions seem to be met but I’m not notified on Slack. I have one point above my alert line, that should fire the alert but it never does :
Would someone have an idea ? Thanks so much for your help !
Any idea please ? :wink:
You may want to consider the time needed to fire the alert. As per my understanding of the documentation the alert goes in a pending state, and after a certain time in alerting. From what I see you need to have the value above 0.5 for 5m to get the alert. Try to put 1s
Hello, thank you, I did change it but no alarm !
Here is the error message I get :
 Object
firing:false
state:""
conditionEvals:“false = false”
timeMs:“42.604ms”
logs:Array[3]
0:Object
message:“Condition[0]: Query”
data:Object
1:Object
message:“Condition[0]: Query Result”
data:Object
2:Object
message:“Condition: Eval: false, Query Returned No Series (reduced to null/no value)”
data:null
