Alert query returning too many rows
I’m using Influxdb and am trying to create an alert that will tell me if the number of data points from the previous hour is below a certain threshold. (In other words, I want to look at the dataset for a completed hour, not the current hour since all data point will not yet be collected.) Looking at the debug info, I see that the following query is generated:
SELECT count("value") FROM "rf_status" WHERE time > now() - 2h and time < now()-1h group by time(1h)
This results in 2 rows of output as shown most easily via testing via the influx cli:
time                 count
2020-12-19T18:00:00Z 15
2020-12-19T19:00:00Z 3
Removing the group by clause produces the correct results which in this case is a single row with a value of 18.
The problem with the group by is that when running inside grafana the alert only seems to look at the last row returned resulting in a false positive alert.
How can I tell grafana to only return a single row?
Here’s the rule test output:
  "firing": true,
  "state": "alerting",
  "conditionEvals": "true = true",
  "timeMs": "3.393ms",
  "matches": [
      "metric": "rf_status.count",
      "value": 2
  "logs": [
      "message": "Condition[0]: Query",
      "data": {
        "from": 1608403625734,
        "queries": [
            "refId": "A",
            "model": {
              "groupBy": [
                  "params": [
                    "1h"
                  "type": "time"
              "measurement": "rf_status",
              "orderByTime": "ASC",
              "policy": "default",
              "query": "SELECT count(\"value\") FROM \"rf_status\" WHERE $timeFilter GROUP BY time(1h)",
              "rawQuery": false,
              "refId": "A",
              "resultFormat": "time_series",
              "select": [
                    "params": [
                      "value"
                    "type": "field"
                    "params": [],
                    "type": "count"
              "tags": []
            "datasource": {
              "id": 7,
              "name": "InfluxDB-weather"
            "maxDataPoints": 0,
            "intervalMs": 0
        "to": 1608407225734
      "message": "Condition[0]: Query Result",
      "data": {
        "series": [
            "name": "rf_status.count",
            "points": [
                3,
                1608400800
                15,
                1608404400
      "message": "Condition[0]: Eval: true, Metric: rf_status.count, Value: 2.000",
      "data": null
thats basically impossible at the moement
Any suggestions as to how to achieve similar results?
no not possible at the moment.
