So I have a CT sensor logging Watt values in influxDb (I believe every 10 seconds).
The CT sensor is on a pool filter pump that runs approximately 8 hs per day consuming about 2.2KW per hour = 2.2kWh
I’m trying to get Grafana to show this when I filter the view by the last 24hs.
I can sum all the values for the particular entity for the last 24hs, but then I need to divide it for the number of hours the pump was actually running and I’m not sure how to do that…
If the pump would be running ALL the time, I would divide the total sum of values by 24 and that would be it. but since it is not running all the time, I’m not sure how to do it…
I’m sure I’m not the first one trying to do this… is there any link or example of somebody that has already done it, that you can share…
I was hoping you guys could help me…
here is the query…
“xhrStatus”: “complete”,
“request”: {
“method”: “GET”,
“url”: “api/datasources/proxy/1/query”,
“params”: {
“db”: “homeassistant”,
“q”: “SELECT sum(“value”) / 24 FROM “W” WHERE (“entity_id” = ‘pool_power_monitor_total_watts_filter_pump_ct1andct2’) AND time >= now() - 24h GROUP BY time(15m) fill(null)”,
“epoch”: “ms”
“data”: null,
“precision”: “ms”
“response”: {
“results”: [
“statement_id”: 0,
“series”: [
“name”: “W”,
“columns”: [
“time”,
“sum”
“values”: [
1571944500000,
null
1571945400000,
8060.474999999999
1571946300000,
8130.712499999997
1571947200000,
8333.637499999999
1571948100000,
8312.941666666664
1571949000000,
8252.012499999999
1571949900000,
8321.245833333334
1571950800000,
3055.454166666666
1571951700000,
0.11666666666666671
1571952600000,
0.12916666666666674
1571953500000,
0.15416666666666676
1571954400000,
0.18750000000000008
1571955300000,
0.1625000000000001
1571956200000,
0.17500000000000007
1571957100000,
0.17916666666666672
1571958000000,
0.22500000000000006
1571958900000,
0.1958333333333334
1571959800000,
0.25000000000000006
1571960700000,
0.27083333333333337
1571961600000,
0.30833333333333335
1571962500000,
0.2166666666666667
1571963400000,
0.1166666666666667
1571964300000,
0.23333333333333336
1571965200000,
0.22083333333333335
1571966100000,
0.004166666666666667
1571967000000,
0.16666666666666674
1571967900000,
0.22500000000000006
1571968800000,
0.2625
1571969700000,
0.27083333333333337
1571970600000,
0.26666666666666666
1571971500000,
0.23750000000000004
1571972400000,
0.25000000000000006
1571973300000,
0.2166666666666667
1571974200000,
0.25833333333333336
1571975100000,
0.23750000000000004
1571976000000,
0.2291666666666667
1571976900000,
0.23750000000000004
1571977800000,
0.3125
1571978700000,
0.2083333333333334
1571979600000,
0.21250000000000005
1571980500000,
0.2166666666666667
1571981400000,
0.2625
1571982300000,
0.23750000000000004
1571983200000,
0.25000000000000006
1571984100000,
0.28750000000000003
1571985000000,
0.25833333333333336
1571985900000,
0.20833333333333337
1571986800000,
0.28750000000000003
1571987700000,
0.2833333333333334
1571988600000,
0.26666666666666666
1571989500000,
0.2541666666666667
1571990400000,
0.21250000000000005
1571991300000,
0.28750000000000003
1571992200000,
0.25000000000000006
1571993100000,
0.28750000000000003
1571994000000,
0.28750000000000003
1571994900000,
0.2625
1571995800000,
0.325
1571996700000,
0.23750000000000004
1571997600000,
0.3
1571998500000,
0.25833333333333336
1571999400000,
0.2625
1572000300000,
0.3
1572001200000,
0.23333333333333336
1572002100000,
0.28750000000000003
1572003000000,
0.4291666666666663
1572003900000,
0.3458333333333332
1572004800000,
0.3666666666666665
1572005700000,
0.3458333333333332
1572006600000,
0.3749999999999998
1572007500000,
0.35416666666666646
1572008400000,
4767.224999999999
1572009300000,
8742.758333333328
1572010200000,
8443.054166666667
1572011100000,
9575.549999999996
1572012000000,
9179.833333333332
1572012900000,
9390.108333333332
1572013800000,
9786.912499999997
1572014700000,
10046.383333333339
1572015600000,
9875.675000000001
1572016500000,
9397.691666666666
1572017400000,
9096.866666666667
1572018300000,
9404.420833333328
1572019200000,
8239.437500000004
1572020100000,
9726.141666666672
1572021000000,
10665.729166666666
1572021900000,
9171.425
1572022800000,
8137.112500000002
1572023700000,
8337.045833333335
1572024600000,
8137.741666666666
1572025500000,
8344.079166666665
1572026400000,
7940.125000000001
1572027300000,
8341.99166666667
1572028200000,
8142.137499999998
1572029100000,
8247.216666666669
1572030000000,
8061.658333333333
1572030900000,
8277.829166666666
