API calls returning 401 unauthorized in curl, python, etc. Possibly due to LDAP?
    Windows, Grafana 7.5.11
    I am trying to get data from API calls (any API call right now for testing, but my goal is to try to find all of the teams that a user viewing a dashboard belongs to). I am trying to initially just test out the APIs before incorporating them into my application (Angular/.NET app).
    I’ve been trying to call the APIs via curl, Insomnia (like Postman), and via Python script. I created an api key, set it as admin, and used this key in my api calls (shown below).
  • What happened?
    I receive a 401 unauthorized message. Specifically:
This server could not verify that you
are authorized to access the document
requested. Either you supplied the wrong
credentials (e.g., bad password), or your
browser doesn’t understand how to supply
the credentials required.
    I am expecting a successful response based on what Grafana documentation outlines and based on my research that others have used the same code/commands to get this working.
Here are my code excerpts:
curl:
curl -k -H "Authorization: Bearer <apikey>" https://<grafanaurl>/api/dashboards/home
python:
import json
import requests
server= "https:<grafanaurl>"
url = server + "/api/dashboards/home"
headers = {
    "Authorization": "Bearer <apikey>",
    "Accept": "application/json",
    "Content-Type": "application/json"
r = requests.request("GET", url, headers=headers, verify=False)
print(r)
# print(r.json())
Nothing in the logs or on the UI
I followed the Grafana documentation for calling APIs, specifically the basic one to get the home dashboard: Dashboard HTTP API | Grafana documentation
I do see that we have basic auth enabled, but we also use LDAP authentication (so when a Grafana user opens the dashboard they do not need to sign in, it takes our organizations credentials). Does that have something to do with why this doesn’t work? I’ve tried adding my AD credentials into the api call when using Insomnia but that didn’t work either.
What do you get with this approach?
import requests
headers = {"Authorization": "Bearer zimzam"}
print(requests.get(url , headers=headers).json())
I get the following error on the print (removed hostname):
HTTPSConnectionPool(host=‘grafanaurlhere’, port=443): Max retries exceeded with url: /api/dashboards/home (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:997)’)))
You got certs issues? you configured grafana with certs but you are calling the api from a resource that is not specifying the cert or is not trusted?
Seems more like a configuration issue with certs and all than a grafana issue?
For testing purposes only maybe try this.
resp = requests.get('https://example.com', verify=True, cert=['/path/to/my/ca.crt'])
any solutions on this, How can we resolve the configuration with certs …
import requests
server= “https://localhost:3000
url = server + “/api/dashboards/home”
headers = {“Authorization”: “Bearer =##my api key##”}
print(requests.get(url , headers=headers, verify=False).json()) for this code i am getting requests.exceptions.SSLError: HTTPSConnectionPool(host=‘localhost’, port=3000): Max retries exceeded with url: /api/dashboards/home (Caused by SSLError(SSLError(1, ‘[SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:992)’))) this error
