Assigning roles to Azure Groups does not reflect on users
    v8.5.2
    I’m trying to authenticate & authorize users using Azure Active Directory (AAD).
    We have some groups that include many users. Instead of assigning roles to individual users, I want to roles to groups, and I want that role assignments to reflect when users of those groups log into Grafana.
  • What happened?
    The assigned roles of the groups did not reflect on their members, so I am not able to authenticate/authorize users unless I manually assign roles for them which is a hassle.
    I expected that the assigned group roles will reflect on the users/members of those groups.
#################################### Azure AD OAuth #######################
[auth.azuread]
name = Azure AD
enabled = true
allow_sign_up = true
client_id = <client-id>
client_secret = <client-secret>
scopes = openid email profile
auth_url = https://login.microsoftonline.com/<tenant-id>/oauth2/v2.0/authorize
token_url = https://login.microsoftonline.com/<tenant-id>/oauth2/v2.0/token
allowed_domains =
allowed_groups =
role_attribute_strict = true
After some investigations, I found out that the cause of the issue is from Azure AD not Grafana.
As can be seen in this warning message, the role assignments won’t be cascaded to nested groups. Only direct users will get access. I tested access on direct and it works as expected.
