Latest docker version -
Setup Azure AD OAuth2 -
What happened?
When trying to login I get the following error: “oauth2: cannot fetch token: 401 Unauthorized\nResponse: {"error":"invalid_client","error_description":"AADSTS7000218: The request body must contain the following parameter: ‘client_assertion’ or ‘client_secret’.” -
I’ve set the following environment variables in docker:
GF_AUTH_AZUREAD_ENABLED: "true"
GF_AUTH_AZUREAD_CLIENT_ID: "redacted (Application ID)"
GF_AUTH_AZUREAD_CLIENT_SECRECT: "redacted (Client Secret)"
GF_AUTH_AZUREAD_AUTH_URL: "https://login.microsoftonline.com/redacted (tenant-id)/oauth2/v2.0/authorize"
GF_AUTH_AZUREAD_TOKEN_URL: "https://login.microsoftonline.com/redacted (tenant-id)/oauth2/v2.0/token"
GF_AUTH_AZUREAD_SCOPES: "openid email profile"
GF_AUTH_AZUREAD_ALLOW_ASSIGN_GRAFANA_ADMIN: "true"
Did you follow any online instructions? If so, what is the URL?
I’ve followed the official tutorial.
