Azure Monitor Data source error
  • What Grafana version and what operating system are you using? v10.0.1
    Connect to Azure Data source with App Registration.
    – App Registration.
  • What happened?
    Within my Organization with Local Grafana installed on VM
**Getting errors : **
One or more health checks failed. See details below.
Details
1. Error connecting to Azure Monitor endpoint: health check failed: Get “https://management.azure.com/subscriptions?api-version=2020-01-01”: dial tcp 20.51.10.137:443: i/o timeout
2. Error connecting to Azure Log Analytics endpoint: health check failed: Get “https://management.azure.com/subscriptions//providers/Microsoft.OperationalInsights/workspaces?api-version=2017-04-26-preview”: dial tcp 20.51.10.137:443: i/o timeout
3. Error connecting to Azure Resource Graph endpoint: health check failed: Post “”: dial tcp 20.51.10.137:443: i/o timeout
also this error :
An error occurred while requesting resources from Azure Monitor
Unexpected token ‘u’, “unexpected”… is not valid JSON
connect :slight_smile:
Your VM doesn’t have network connectivity to Azure.
Thanks, I have enabled port 443 to all, what else should i do ?
