Bar chart Energy consumption per day with graphite
Hello!
I’m trying to plot a bar chart which display energy consumption per day, for the last 7 days, for example. Should look like this:
I have a series which holds the total energy consumption and from that i have to calculate the consumption the last 24 hours, thats how far i’ve gotten, but how do i do that for the last x days?
I am using graphite as my data source!
Help would be very appreciated,
what is your query for calculating the last day of energy consumption? It sounds like you might be able t template that query using template variables. then you choose the number of days from a select dropdown
Here are the docs on template variables. And here is a list of good examples on play.grafana.org that use template variables. You can inspect each dashboard to see just how the variables are constructed.
See the solution here: https://localhost:3000/t/default-datetime-formatting-to-weekday-possible/60702/3?u=originschnudl
