i startet with grafana and needs a bar gauge.
The max value does not work. so the bar is on the left side.
Maby the “auto” max looks at the real max value? I have set the bar to delta.
Hi @bsahrdt,
Welcome to the community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community
Try to view some more visualisation by clicking the “suggestions” as also attached in the image as it will suggest some pre-configured panels including bar-gauge with some additional settings for visuals.
I hope this helps.
OK, Thanks. I Can found it.
