Do you know of any plugin that I can use to do url based authentication?
basically, i want to call
api.domain.tld/centreon/api/index.php?action=authenticate
provide it user name and password in Body form-data:
@yosiasz have you checked out the json plugin?
sure did. I don’t believe it provides what we need. It does not allow for body form-data that I could see. Going to try another route
I haven’t tried it, but it allows custom headers so you could specify the content-type. The dev mentioned in this discussion:
The body isn’t limited to JSON, you could put any day there, such as
value1=foo&value2=bar
. If you set the header toContent-Type: multipart/form-data
, wouldn’t that work
hmm sounds promising let me try that.
not working could be CORS issue. Will keep trying by checking the log on the target server
