We did some configuration with blockbox_exporter, It is showing normal in Prometheus , But in grafana dashboard some nodes showing Down,
Any one can see this issue
GRAFANA FORUM’S 3 BEST PRACTICES:
- Please post inside a subcategory
- For questions and advice, please try to use the template below
- If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
What happened?
Did you follow any online instructions? If so, what is the URL?
