Bloody beginner needs help with time interval on panels
Hi folks,
I use Grafana for HomeAssistant v8.1.0 with InfluxDB
I have two panels on my dashboard and I want to see an 24 hour trend on ther first panel and a 1 year trend on the second panel when I open it.
Unfortunately there is allways a 6 hour trend after opening.
I don’t find the poit where to configure it.
Is ther someone who wants to show me how it works?
regards
Bernd
Change the time selector to what you want (I put 3 hours):
then save the dashboard using the Save icon and check the box as shown:
Or, if you want just certain panels to display certain time ranges, use the Query Options:
and you will see this:
Many, many thanks. <3
