installation with docker image grafana/grafana:latest -
I’m trying to make a connexion through auth proxy and generic_oauth. -
On different git branch, they works, when merge, configuration makes some conflict about the redirection of the auth proxy -
What happened?
Grafana message Serve error -
Is it possible to make both connexion, if yes, have you the solution or indicate the methods. -
Did you follow any online instructions? If so, what is the URL?
