Built panel plugin doesn't load
I have created a new plugin via npx @grafana/toolkit plugin:create . I added the visualisation to a dashboard but I get an error alert “Error loading: my plugin name”.
In the dev tools console there is the error:
GET http://grafana.staged-by-discourse.com/public/tslib?_cache=1640355273357 404 (Not Found)
I haven’t changed any of the code in the generated plugin, just built it. All I have done is install the latest version of postcss due to an error encountered when building.
All seems to be ok now - I was using NPM, but switched to Yarn as per the tutorial.
