Calculating Avg of a variable from ES datasource
I have the json data in Elastic Search as below.
    "responsetime": "100",
    "operation": "api1"
    "responsetime": "200",
    "operation": "api2"
    "responsetime": "110",
    "operation": "api1"
I want to display this in a table with the below columns.
OperationName
AvgTime
MinTime
MaxTime
Can you please assist !
Here is my Grafana screen. I was trying to bring Avg column first !!
@mefraimsson Could you please assist with this issue
You can’t do averages on a string field. That’s not a Grafana issue, it’s Elasticsearch limitation. Please re-index your data to use numeric response time instead.
Thanks. Your solution on the below solved this issue too
https://localhost:3000/t/filter-based-on-a-column/16569/5
