- What Grafana version and what operating system are you using?
v8.3.4 ubuntu
I’m trying to show the success rate of a github workflow in a grafana panel -
I’m collecting cloudwatch metrics for the success rate of a github workflow, it saves success as 1 and fail as 0, i want to be able to show the success rate of the workflow over the period of time that is in the time range of the dashboard. -
What happened?
found no easy way to collect the datapoints this way, i had to resord to using a custom interval variable in the period to be able to collect data points across a certein amount of time and use sum and samplecount to figure out how many failed and succeeded. also i can’t set the period of the query to the time range of the dashboard as the grafana global variables don’t seem to work in this field. -
expected to be able to get the count of the value of a certain metric more easily and also be able to count over time range more easily -
not really -
no -
Did you follow any online instructions? If so, what is the URL?
tried using these Global variables | Grafana documentation to no success
