Cannot set required precision in Stat panel
I can’t set the required precision in my Grafana Stat panel:
  • current format: €-1.012K
  • required format: €-1012.97
In the original Singlestat panel, I could circumvent this issue by using a “€” prefix but Stat doesn’t seem to offer this flexibility or any other workaround. Grafana 8.4.7
Any known workaround?
could you please post sample data coming from the data source?
moneytalks
€-1012.97?
-1012.97?
Even with latter data I was only able to set it as -1012.97 using Unit / Standard Options/Unit/Locale Format. But then you lose the euro currency.
Not sure if this is what you mean: data straight from the query inspector:
yld
-1048.38056
Obviously a different (later) value than before. The key problem is that Grafana converts the number to use thousands with the symbol “K”.
This should be rendered as €-1048.38 and not €-1.048K
Any possibility to solve this problem?
