Change built-in metric names
Hello all,
Could I add a prefix to built-in metric names? Something likes **k6_test_**http_reqs. Because I’m working with many teams in Grafana, so I need a unique prefix for distinguish.
Thanks,
Hoang
Hi @vhoang1102,
Which output are you using?
hi @mstoykov , thanks for your response. I’m using Json and InfluxDB.
Hm, both of those don’t actually support prefixing the metrics, can you please open an issue.
As a workaround I guess you can use telegraf to rename them, but haven’t done so and it seems pretty manual, sorry :frowning:
yep, thanks @mstoykov for this information :smiling_face_with_tear:
