I understand how to perform check() when using a single request result (e.g. http.get()). However, when using http.batch(), is it possible to loop over the array elements to check each one? Instead of having to check() each array element individually.
Instead of this:
const batchResponses = http.batch([
["GET", "https://www.example.com/a.html"],
["GET", "https://www.example.com/b.html"],
["GET", "https://www.example.com/c.html"]
check(batchResponses[0], { "Page a HTTP status 200": res => res.status === 200, });
check(batchResponses[1], { "Page b HTTP status 200": res => res.status === 200, });
check(batchResponses[2], { "Page c HTTP status 200": res => res.status === 200, });
As explained in this issue, currently the result of batch is an Object, with keys such as 0, 1, 2, 3 … . We do intend on fixing this but probably it’s going to be done in the a future version of the whole http api as the current one has some … problems .
As a workaround you can see the script below … unfortunately you need to provide the length of the batch ;(
edit: you can use Object.keys(batchResponses).length
import http from "k6/http";
import { check } from "k6";
export default function() {
for (let i = 0; i < 3; i++) {
let element = batchResponses[i];
check(element, { "All HTTP status 200": (r) => r.status == 200 });
console.log(element.url);
