Click on remove panel but doesn't get removed
I have grafana version 7.0.3
I click on remove on the panel but it doesn’t remove it and i have to click on it a few times to actually remove the panel. But when i use the keyboard shortcut it works instantly.
Is this problem with the 7.0.3 version by any chance??
All I can think to ask about this is “do you have any other problems with the
mouse?”
It really seems like not-a-Grafana-problem to me.
Antony.
No problem there but it works fine now it happened on another pc
