Hello!
I display how long it takes, to complete charging a battery to 90%.
When it discharging, I calculate how long it takes to 10%.
I would like to display now the text to the time:
90% reached in xxx
10% reached in xxx
This is my stat display:
This is my flux query:
import "timezone"
option location = timezone.location(name: "Europe/Vienna")
from(bucket: "bucket")
|> range(start: -5m, stop: v.timeRangeStop)
|> filter(fn: (r) => r["_measurement"] == "PV")
|> filter(fn: (r) => r["Wechselrichter"] == "Alle")
|> filter(fn: (r) => r["Speicher"] == "Alle")
|> filter(fn: (r) => r["_field"] == "Lade/Entladeleistung" or r["_field"] == "SoC")
|> filter(fn: (r) => r["_value"] < 20000 and r["_value"] > -20000)
|> aggregateWindow(every: 5m, fn: last, createEmpty: false)
|> pivot(rowKey: ["_time"], columnKey: ["_field"], valueColumn: "_value")
|> map(fn: (r) => ({ r with
Ladezeit: if r["Lade/Entladeleistung"] > 300.0
then
((40500.0 - (45000.0 * r["SoC"] / 100.0)) / r["Lade/Entladeleistung"]) * 60.0 * 60.0
else if r["Lade/Entladeleistung"] < -300.0
then
(((45000.0 * r["SoC"] / 100.0) -4500.0) / r["Lade/Entladeleistung"] * -1.0) * 60.0 * 60.0
else
0.0
|> keep(columns: ["Ladezeit"])
|> yield(name: "last")
Can I change in the flux the column name?
