Compare data on the same Panel for two time Range
I am looking for a way to compare the “gas consumption” of the current year with that of last year.
Can this be realized in Grafana?
I use Grafana and InfluxDB (Flux).
Attached is a picture of how I would like to do it.
Time series 1 = today - 1 year (2023 Today -12 months)
Time series 2 = “today”-1 year - “-1 year” (2022 - 12 months).
I think the picture clarifies quite well what I mean.
Hallo,
ich habe einen Tag zuvor eine ähnliche Anfrage gestellt, aber noch keine Antwort erhalten.
https://localhost:3000/t/dashboard-mit-library-panels-unterschiedlicher-zeiten/81543?u=dgr75
@goodold
Can you share the current Flux query that you have created (just to return the gas consumption over time) and a small subset of the data output? I am pretty sure what you are asking is possible using Flux.
Hi @grant2 ,sorry for the delay:
import "timezone"
option location = timezone.location(name: "Europe/Berlin")
from(bucket: "iobroker")
  |> filter(fn: (r) => r["_measurement"] == "Gaszaehlerstand")
  |> filter(fn: (r) => r["_field"] == "value")
  |> difference()
 |> aggregateWindow(every: 1mo, fn: sum, timeSrc: "_start")
Hi @goodold
OK, this is not a perfect solution, but will hopefully get you started…
In the graph below, I am plotting daily energy usage from 01-Dec to 31-Jan:
Adding these two statements will give you the month-over-month view. More here.
  |> window(every: 1mo)
  |> experimental.alignTime(alignTo: 2021-12-01T00:00:00Z)
You will notice that the start of the graph begins with 30-Nov and for some reason does not have two series displayed for the 30th & 31st. Maybe @ldrascic or @yosiasz can tell me / us why.
Hi @grant2 , thanks it looks good.
But how did you change the colors?
I can not change the separate.
Hi @grant2 can you plz help me again.
with the standart options i can not change the colors separate.
Edit: Solution = Color scheme > "Classic palette
