Hi.
We’re trying to setup Fluent-bit shipping logs to Loki for visualization in Grafana.
As first test we set up a perfectly working Loki-instance with Fluentbit using the Fluent Bit Loki chart which is being used within the Loki-stack Helm-chart: The K8s-labels can be chosen in the Explore-function in Grafana and we can can simply see the unpoluted log-field-value of the logs.
But now we want to setup a Loki-distributed-architecture with the main goal of having an ha-concept. For that the corresponding Helm chart does not include the option to use Fluent-bit (like on the Loki-stack-chart). So now we’re trying to figure out how exactly the Fluentbit-chart has to be set up to get also the functionality like it is using the Loki-stack-chart.
Although there are some small differences in general between the configs of the Loki-Fluent-bit.conf and the Fluent-bit.conf, the main points are still the same:
Loki-fluent-bit.conf:
[SERVICE]
HTTP_Server On
HTTP_Listen 0.0.0.0
HTTP_PORT 2020
Flush 1
Daemon Off
Log_Level warn
Parsers_File parsers.conf
[INPUT]
Name tail
Tag kube.*
Path /var/log/containers/*.log
Parser docker
DB /run/fluent-bit/flb_kube.db
Mem_Buf_Limit 5MB
[FILTER]
Name kubernetes
Match kube.*
Kube_URL https://kubernetes.default.svc:443
Merge_Log On
K8S-Logging.Exclude Off
K8S-Logging.Parser Off
[Output]
Name grafana-loki
Match *
Url http://loki:3100/api/prom/push
TenantID ""
BatchWait 1
BatchSize 1048576
Labels {job="fluent-bit", cluster="hz-nb-dev-rt7-01"}
RemoveKeys kubernetes,stream
AutoKubernetesLabels false
LabelMapPath /fluent-bit/etc/labelmap.json
LineFormat json
LogLevel warn
with the labelmap.json:
"kubernetes": {
"container_name": "container",
"host": "node",
"labels": {
"app": "app",
"release": "release"
"namespace_name": "namespace",
"pod_name": "instance"
"stream": "stream"
Fluent-bit.conf:
[SERVICE]
Daemon Off
Flush 1
Log_Level info
Parsers_File custom_parsers.conf
HTTP_Server On
HTTP_Listen 0.0.0.0
HTTP_Port 2020
Health_Check On
[INPUT]
Name tail
Tag kube.*
Mem_Buf_Limit 5MB
Parser docker
[FILTER]
Name kubernetes
Match kube.*
Merge_Log On
[OUTPUT]
Name loki
Host loki-distributed-distributor
Port 3100
Retry_Limit false
Match *
Labels cluster=xyz, job=fluent-bit
Label_keys $kubernetes['host'], $kubernetes['pod_name'], $kubernetes['container_name']
Remove_keys kubernetes,stream
Line_format json
Auto_kubernetes_labels off
So, do somebody has experience on that? How you can achieve the same easy and simple functionality of the (deprecated) Fluentbit Loki Output Plugin by using the origin Fluent/Fluent-bit-chart, especially for getting easily the log-field-value just by chosing the labels within Grafana?
