grafana/grafana:latest using docker 20.10.17 and docker-compose 1.29.2 running on 5.18.0-1-amd64 Debian 5.18.2-1 (2022-06-06) x86_64 GNU/Linux -
Set up an instance of Grafana with access to grafana.ini in a locally mounted folder -
Used a docker-compose.yml file and a .env file to manage configuration -
What happened?
The following errors in the log file:
$ docker-compose --file /srv/grafana/docker-compose.yml logs
Attaching to grafana
grafana | GF_PATHS_CONFIG='/srv/grafana/config' is not readable.
grafana | GF_PATHS_DATA='/srv/grafana/data' is not writable.
grafana | You may have issues with file permissions, more information here: http://docs.grafana.org/installation/docker/#migrate-to-v51-or-later
grafana | logger=settings t=2022-11-22T17:18:14.42336638Z level=error msg="failed to parse \"/srv/grafana/config\": open /srv/grafana/config: no such file or directory"
For the container to start normally -
docker-compose.yml:
version: "3"
services:
grafana:
image: grafana/grafana-oss:latest
container_name: grafana
hostname: ${HOSTNAME}
user: ${PUID}:${PGID}
environment:
- GF_PATHS_CONFIG=${APPDATA}/config
- GF_PATHS_DATA=${APPDATA}/data
volumes:
- ${APPDATA}/config:/etc/grafana/
- ${APPDATA}/config/grafana.ini:/etc/grafana/grafana.ini # test
- ${APPDATA}/data:/var/lib/grafana
ports:
- "3000:3000"
restart: always
.env file:
# User ID and Group ID
PUID=472
PGID=0
# Directory locations
APPDATA=/srv/grafana
# Host specifics
HOSTNAME=services
Steps followed to create environment:
$ cd /srv/grafana
$ mkdir config/ data/
$ sudo chown -R 472:0 config/ data/
$ ls -la
total 48
drwxr-xr-x 8 idsvc idsvc 4096 Nov 22 10:29 .
drwxr-xr-x 34 idsvc idsvc 4096 Nov 22 10:12 ..
drwxr-xr-x 2 472 root 4096 Nov 22 10:29 config
drwxr-xr-x 2 472 root 4096 Nov 22 10:29 data
-rw-r--r-- 1 idsvc idsvc 1482 Nov 22 10:15 docker-compose.yml
-rw-r--r-- 1 idsvc idsvc 287 Nov 22 10:18 .env
Confirmation of configuration:
$ docker-compose --file /srv/grafana/docker-compose.yml config
services:
grafana:
environment:
GF_PATHS_CONFIG: /srv/grafana/config
GF_PATHS_DATA: /srv/grafana/data
hostname: services
ports:
- published: 3000
target: 3000
restart: always
user: '472:0'
volumes:
- /srv/grafana/config:/etc/grafana:rw
- /srv/grafana/config/grafana.ini:/etc/grafana/grafana.ini:rw
- /srv/grafana/data:/var/lib/grafana:rw
version: '3'
Environment values from running container:
$ docker exec grafana env
PATH=/usr/share/grafana/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
HOSTNAME=services
GF_PATHS_CONFIG=/srv/grafana/config
GF_PATHS_DATA=/srv/grafana/data
GF_PATHS_HOME=/usr/share/grafana
GF_PATHS_LOGS=/var/log/grafana
GF_PATHS_PLUGINS=/var/lib/grafana/plugins
GF_PATHS_PROVISIONING=/etc/grafana/provisioning
HOME=/home/grafana
Mounts from running container:
$ docker container inspect grafana -f '{{range .Mounts}}{{.Type}}:{{.Source}}:{{.Destination}}{{println}}{{ end }}'
bind:/srv/grafana/config/grafana.ini:/etc/grafana/grafana.ini
bind:/srv/grafana/config:/etc/grafana
bind:/srv/grafana/data:/var/lib/grafana
None, UI was unable to start -
Did you follow any online instructions? If so, what is the URL?
I referenced the following:
Run Grafana Docker image | Grafana documentation
Configure Docker image | Grafana documentation
I have followed the direction to use user 472 (grafana) and group 0 (root). I expected grafana.ini to be created on initial run.
