Grafana version 8.5.4 on a Windows 2012 server. Data source is OSIsoft-PI. -
What happened?
I have noticed a reoccurring issue where Configuration/query settings seem to get wiped every few weeks. Panel settings are always saved when altered, and I am only user making edits yet I have to spend hours every month or so to restore configuration.
Has any else experienced this issue? Is there a robust way to save the configuration file? -
Query settings to be set until changed. -
In particular, query summaries are one of the settings I am noticing being overwritten quite often.
