We have a grafana server with version 6.3 running on a AWS EC2 instance. It is using the default sqlite3 database which is in /var/lib/grafana/ location on the server.
Now, we would like to implement high availability for grafana such that the grafana server will be using a MYSQL database that is hosted through AWS RDS.
I was able to get the sqlite3 database and convert into Mysql by following this guide and was able to access all data through sql workbench.
Now, I installed a fresh 6.3 version of grafana on a new instance and configured it such that it uses the Mysql database on RDS.
I can see the dashboard names and was able to login with existing usernames but when I access dashboards, I get empty dashboards. Can anyone help me please?
Thank you!
