container_cpu_user_seconds_total - Return data container_cpu_user_seconds_total{id=“/”,instance=“10.0.4.70:8080”,job=“cAdvisor”} 656.14
rate(container_cpu_user_seconds_total[1m]) - Return data
{id=“/”,instance=“10.0.4.70:8080”,job=“cAdvisor”} 0.0007272595043719863
3.rate(container_cpu_user_seconds_total{image!=“”}[1m]) - Return no data
4. sum(rate(container_cpu_user_seconds_total{image!=“”}[1m])) - Return no data
5. sort_desc(sum(rate(container_cpu_user_seconds_total{image!=“”}[1m]))) - Return no data
I will be happy to understand what that means and what has to be done to fix it.
You are correct!!! I just installed for the first time Grafana and used some of the dashboards referred there for docker. These dashboards are with pre build queries.
So I have removed the image part and it is working!!!Thanks a lot!!!
Any idea why did they added the image part?
