I am using Grafana 7.5.5 on an Ubuntu machine to display data stored in InfluxDB 1.8 in a different Ubuntu machine.
To do that I created a connection pointing to InfluxDB. When saving data source, Half of the time I get this error: InfluxDb Error: database not found : <database_name>, the other half the connection is correctly made.
I tried to use the connection to display some data. However, I faced the same issue, the InfluxQL requests are not always correctly executed.
I did some troubleshooting by executing the requests manually on the instance. I had no problems with that.
I checked Grafana logs, I received nothing suspicious . Same goes for InfluxDb.
Is that specified as an IP address or as a hostname?
If it’s a hostname, can you confirm that it resolves to just the single address
of the InfluxDB server?
Do you have any opportunity to do a packet capture on either the machine
running Grafana or the machine running InfluxDB to look at communications going
to (presumably) TCP port 8086 on the InfluxDB machine, to check whether the
correct DB name is being requested every time, and sometimes failing, or
whether the correct name is only sometimes beign requested?
Again, a packet capture would help here, I think.
Make sure that there is a communication every time you do a query, and also
look at what the query is - whether it contains the correct, or perhaps some
corrupted, database name.
Unfortunately, I can’t perfor a packet capture on both instance as I am only a user.
For the connection to influx, I am using a load balancer redirecting grafana to it.
