Connection reset by peer after following grafana tutorial (prometheus + node exporter)
Recently I installed node exporter + prometheus in order to have monitoring on my proxmox server. I followed the guide on grafana website: Monitoring a Linux host using Prometheus and node_exporter | Grafana Cloud documentation
I installed node exporter on my server + prometheus with the following yaml
Then I created a dashboard, and data are here, after that I created some alert rules as you can see below:
But sometimes I received error email, but data are fine, no error logs but the only error message I get is on the alert dashboard:
failed to query data: Post “https://prometheus-prod-01-eu-west-0.grafana.net/api/prom/api/v1/query_range”: read tcp 10.148.11.73:50936->34.117.67.173:443: read: connection reset by peer
What is the meaning of this error ? 34.117.67.173 is an google cloud server and 10.148.11.73:50936 I dont know
Do you have any idea ? Its annoiyng I received false positive mail :frowning: The error is present 2/3 times during a day but only during 1mn…
A second sreenshot:
Data are sent to grafana cloud
