Team,
I have an existing Grafana running as part of the dependency for prometheus-operator/kube-prometheus-stack chart. Grafana has a single Organization and few dashboards. I am trying to provision a new dashboard which should be created in a new Organization.
Here is the values.yaml snippet configuration I tried:
dashboardProviders: dashboardproviders.yaml: apiVersion: 1 providers: - name: "app1Dashboards" orgId: 1 folder: "" type: file disableDeletion: false allowUiUpdates: false options: foldersFromFilesStructure: false path: /tmp/dashboards - name: "app2Dashboards" orgId: 2 folder: "" type: file disableDeletion: false allowUiUpdates: false options: foldersFromFilesStructure: false path: /tmp/app2/dashboards
However, using this configuration I encountered an error:
> t=2021-02-09T09:03:02+0000 lvl=eror msg="Failed to provision dashboard" logger=provisioning error="Failed to create provisioner: Failed to read dashboards config: failed to provision dashboards with "app2Dashboards" reader: Organization not found"
> t=2021-02-09T09:03:02+0000 lvl=eror msg="Stopped ProvisioningService" logger=server reason="Failed to create provisioner: Failed to read dashboards config: failed to provision dashboards with "app2Dashboards" reader: Organization not found"
> t=2021-02-09T09:03:02+0000 lvl=eror msg="A service failed" logger=server err="Failed to create provisioner: Failed to read dashboards config: failed to provision dashboards with "app2Dashboards" reader: Organization not found"
> t=2021-02-09T09:03:02+0000 lvl=eror msg="Server shutdown" logger=server reason="Failed to create provisioner: Failed to read dashboards config: failed to provision dashboards with "app2Dashboards" reader: Organization not found"
My use-case scenario is APP1 is for teamA and APP2 is for teamB and neither should be able to access the other Dashboard(s).
How do I create(provision) the second Org in helm chart?
