Hey guys, I have some logs stored in loki, and the log lines have the following fields / labels:
- node_id
- block_height
- block_id
The logs are aggregated coming from multiple instances of a service (node_id
is the instance id).
For example, if I make the following query in the log browser:
{app="execution",network="mainnet16"} | json | block_height="24439205"
then I might get the following results:
2022-02-19 17:50:37
{"node_id":"9686399a8a5418a12e762cfaeff2ea348c2137f554560917760e0d47acf2cda4","block_id":"6eba203f896e84f07103dbbad22a99968e1c3b8763e07db759806091ad0d12c2","block_height":24439205}
2022-02-19 17:50:35
{"node_id":"4ab025ab974e7ad7f344fbd16e5fbcb17fb8769fc8849b9d241ae518787695bd","block_id":"6eba203f896e84f07103dbbad22a99968e1c3b8763e07db759806091ad0d12c2","block_height":24439205}
2022-02-19 17:50:35
{"node_id":"0ca407c1da940952ebcc02283b60cd97c9a008e111a48ea6cf1ce8f36f1e0153","block_id":"6eba203f896e84f07103dbbad22a99968e1c3b8763e07db759806091ad0d12c2","block_height":24439205}
2022-02-19 17:50:35
{"node_id":"160241f88cbfaa0f361cf64adb0a1c9fc19dec1daf4b96550cd67b7a9fb26cd9","block_id":"6eba203f896e84f07103dbbad22a99968e1c3b8763e07db759806091ad0d12c2","block_height":24439205}
I’d like to achieve the following:
- For a given
block_height
, compute the number of distinctblock_id
values. In the example above, the value would be 1 because all four log lines have the sameblock_id
value. - Create a dashboard for this value, where
block_height
is on the x-axis, and the value as computed above is the y-axis.
Can anyone point me in the right direction on how to do this, or know if this is even possible? At the moment, I’m just trying to simply compute the number of distinct block_id
values for a single block_height
, and I can’t seem to even get that working. Thank you very much for the help.
