Custom grafana Panel Plugin with React public/@emotion/react?_cache=1636627706343 404 (Not Found). system.js
    Grafana 8.2.3
    MacOS 10.15.7
    I’m creating a custom plugin with react to have a material icons in Panel Plugin
    I used a template from grafana documentation, and building over it search bar in a panel with material icons
  • What happened?
    I’m getting error for public/@emotion/react?_cache=1636627706343 404 (Not Found). system.js
    but public/plugins/plugin-test/module.js?_cache=1636627706343 works fine
    The expectation is library path should be correct
    default.ini configurations
  1. Request URL:
    http://grafana.staged-by-discourse.com/public/@emotion/react?_cache=1636627706343
  2. Request Method:
    GET
  3. Status Code:
    404 Not Found
Have someone faced the same issue? Thanks for help in advance.
The path to the icon looks a bit weird to me. Could you show how you’re using the icon in your code?
I am also facing this issue by just installing the plugin
INFO[01-17|08:44:07] Request Completed                        logger=context userId=1 orgId=1 uname=admin method=GET path=/api/plugins/marcusolsson-calendar-panel/markdown/help status=404 remote_addr=[::1] time_ms=11 size=68 referer="http://grafana.staged-by-discourse.com/plugins/marcusolsson-calendar-panel?page=overview"
INFO[01-17|08:44:11] Downloaded marcusolsson-calendar-panel v0.5.0 zip successfully logger=plugin.installer
INFO[01-17|08:44:11] Plugin registered                        logger=plugin.manager pluginId=marcusolsson-calendar-panel
INFO[01-17|08:44:11] Request Completed                        logger=context userId=1 orgId=1 uname=admin method=GET path=/public/emotion status=404 remote_addr=[::1] time_ms=21 size=37403 referer="http://grafana.staged-by-discourse.com/plugins/marcusolsson-calendar-panel?page=overview"
I also have the same issue with @emotion/react with our Druid Grafana plugin. I’ve tried adding to install it using the package.json’s devDependencies and Dependencies with no success.
Any advice would be appreciated.
I think I had a conflict between @emotion/react and @emotion/css. I went solely with @emotion/css and used its injectGlobal to do what I needed…
injectGlobal(`
  .react-datepicker__triangle {
    display: none;
  .react-datepicker-popper {
    z-index: 1000 !important;
