Custom naming in first column of Table
Hi everyone. I am kind of new to Grafana and still learning how to use it. I am playing around with a dashboard for my house power consumption. I am having a few issues where I might need help with also beside the issue I will describe below using the template that this community is providing. Hope anyone can help me with that. Let me know if any other information is needed.
    Grafana Version 9.1.1 within a Docker Container on my Synology Diskstation
    I have a table on my dashboard showing min, mean and max values for each phase. I want to put custom naming in the first column.
    Target
    That´s exactly my question… :slight_smile:
  • What happened?
    I am not able to set custom naming for the two highlighted fields since they are empty. So no value mapping possible.
    I did expect to find a solution, but after several weeks of playing around I was not able to find a solution.
    I for sure could. But I don´t know what is needed.
    Nope. No errors. Issue might just be my lack of knowledge of flux language
    No. I would be happy to know where I could find informations like this.
