My manager wants me to customize the dashboard. He wants me to make one landing page when a user log in to a grafana, and in that dashboard there should be buttons that will redirect to a particular dashboard.
I’ve created buttons using panels from the dashboard but I want to customize everything from colors to the whole look of the dashboard which I cannot do using panels.
How can I customize it? Is it possible? And which code should I change?
Following is the example of dashboard I have made so far and it is working fine but i want to change icons, colors, and look of the dahsboard and make more presentable
You can set disable_sanitize_html = true and then use text panel, where you can set own custom html/css.
Serious solution will be development of own plugin/panel, which will fit your needs.
You could try and edit some core files, but that would require maintenance every time a new update/version is released which might not work the same with your alterations as the older version did.
