I have a dashboard with several gauges and graphs. One of the gauges I wanted to change to a D3 gauge, so I installed the plugin and restarted the server. Then I configured/added a new panel to the dashboard, and selected the D3 gauge visualization. I added the query, which selects the top (1) to get the latest value, and set the format to table. When I clicked apply the gauge appeared, but indicated 0 (zero) - needle is at 0 zero, also. When I did the exact same thing with a core gauge, the gauge displays the value correctly. It’s a simple query, and I verified that the query returns a single value.
Any thoughts/suggestions on how I can get the D3 gauge to work?
Thanks,
Stephen Johnson
