- What Grafana version and what operating system are you using?
v9.5.0-cloud.4.a016665c
- What are you trying to achieve?
For my dashboard panels to be in n columns — let’s say 2 for this example. For example, adding 6 panels should result in 3 rows of 2 equally sized panels.
- How are you trying to achieve it?
Via a Terraform template, which is part of the problem
When I add them in this way, I do not know how many panels there will be, and so can not predict the x, y coordinates of gridPos
. I’ve tried:
"gridPos": {
"h": 10,
"w": 12,
"x": 0,
"y": 0
attempting to set "w": 12
to equal half the columns, as the documentation states, but this still doesn’t solve the problem of the x
and y
coordinates needing to be set. I’ve tried leaving those out too, but that makes no difference.
- What happened?
All panels are stacked on top of each other, no matter their width.
I’ll just paste an example panel section, since it should illustrate the issue well (the ${}
variables are for Terraform to fill in):
"title": "${this_function} Concurrent Executions",
"type": "timeseries",
"datasource": {
"type": "cloudwatch",
"uid": "${datasource_uid}"
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisCenteredZero": false,
"axisColorMode": "text",
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "line",
"fillOpacity": 0,
"gradientMode": "none",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "none"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 10,
"w": 12,
"x": 0,
"y": 0
"id": 1,
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom",
"showLegend": true
"tooltip": {
"mode": "single",
"sort": "none"
"targets": [
"datasource": {
"dimensions": {
"FunctionName": "${application_name}-${this_function}"
"expression": "",
"id": "",
"label": "",
"logGroups": [],
"matchExact": true,
"metricEditorMode": 0,
"metricName": "ConcurrentExecutions",
"metricQueryType": 0,
"namespace": "AWS/Lambda",
"period": "",
"queryMode": "Metrics",
"refId": "A",
"region": "default",
"sqlExpression": "",
"statistic": "Average"
