Hello there,
I’m trying to import a previously exported dashboard through the api/dashboards/db
API.
Even if the exported var is available in the __inputs
section of the JSON, it is not used and replaced by the ${VAR_TESTVARIABLE}
value :
"__inputs": [
"name": "DS_MY_CLOUDWATCH",
"label": "my_cloudwatch",
"description": "",
"type": "datasource",
"pluginId": "cloudwatch",
"pluginName": "CloudWatch"
"name": "VAR_TESTVARIABLE",
"type": "constant",
"label": "TestVariable",
"value": "i-0b7a61efe2aa955ff",
"description": ""
When I import manually the dashboard, the var is correctly filled in and i have only to select the datasource.
I’m using Grafana 5.0.3 (commit: 91162f3) on CentOS 7.
Shall I open a bug on the github or is this something unsupported ?
Kind regards,
/Lenain
