- What Grafana version and what operating system are you using?
V.9.3.2
i want to ´creat Time series queries with mutiple Graf in one pannel.
i mean , i want to overlay several Graf in one panel by using just one code. -
on only able to achive it by chossing separently
SELECT
“Power” AS “value”,
“Zeit” AS “time”
FROM
“Haus”
WHERE
“hause_Numbe” = 1
- What happened?
i habe to define all 10 Hause manuelly. - What did you expect to happen?
i’m expectiong just on function where a chose group By Hausnumber.
so it will automaticlally know that a have 10 Hause an giving me 10 Grafs in one Panel
Did you follow any online instructions? If so, what is the URL?
PostgreSQL data source | Grafana documentation
