- Version 10.0.1 (commit: 5a30620, branch: HEAD)
- Monitoring some metrics when using Erigon Prometheus
Step 0:
- Run prometheus locally
./prometheus --config.file=./prometheus.yml --web.listen-address=:9010
The prometheus.yml is
global: scrape_interval: 10s scrape_timeout: 3s evaluation_interval: 5s scrape_configs: - job_name: erigon # example, how to connect prometheus to Erigon metrics_path: /debug/metrics/prometheus scheme: http static_configs: - targets: - XXX.XXX.XXX.XX:6060
Step 1:
- Open Grafana and add data source of Prometheus, the URL is set to
http://localhost:9010
Step 2:
- Now import dashboard, the json template is from https://github.com/ledgerwatch/erigon/blob/devel/cmd/prometheus/dashboards/erigon.json
Step 3:
- Wait for the browser to crash. Error message says: “Templating init failed e.replace is not a function.”
What happened?
- Templating init failed e.replace is not a function when I use Erigon Prometheus.
- Some metrics should be shown like
- Templates in Step 2.
- Yes.
shows.
- Yes.
Did you follow any online instructions? If so, what is the URL?
No. However, this bug does not seem to be the first time it has appeared, and many people have mentioned it before
- https://localhost:3000/t/templating-namespace-error-updating-options-e-replace-is-not-a-function/66691/1
- Error: e.replace is not a function - after creating data link in field override #28714
Their fix was to upgrade grafana, but the version we’re currently using is the latest.
Sorry for some links are missing because I can only put at most 2 links
