Data links in Stat panel with __data.fields
Hello everyone,
Grafana v8.5.2 in Docker Container
I want to have a Data link on the Stat Panel, with some data from the query
https://example.com?foo=${__data.fields.foo} .
  • What happened?
I was able to select the data field in the Data Link dialog, but later it does not get substituted in the URL when I click or hover on the stat panel.
The variable gets substituted like in the table panel.
Has anyone tested this and can confirm the behaviour?
I would then raise a git issue about this problem.
