I have a graphite datasource that is running on the same server as grafana. Graphite and grafana are using https. I had to use a self signed cert. Graphite works you just get the cert error/warning about an untrusted site. I could not get grafana to connect to graphite using https. I get a 502 bad gateway error. I’m sure its the cert warning causing the problem. If I switch graphite back to http the datasource works in grafana. Is there a way to define a datasource in grafana that uses a self signed cert?
You can sacrifice TLS security (not very secure option) - check Skip TLS Verify
IMHO better option will be to generate TLS certs for Graphite with own CA - then you can configure used CA cert in Grafana: With CA Cert
, so won’t need to skip TLS verify. See your datasource configuration:
That did the trick. I agree with your better option but this is a poc. When I make this live I will be taking your advice.
Thanks for the quick response.
