Datetime Showing Different Than SSMS
    8.0.0
    Pulling the correct datetime value
    Converting my datetime field to the format “MM-dd-yyyy hh tt”
  • What happened?
    After converting my datetime field to the time field so I can view it on a graph, it actually shows 04:00:00 instead of 09:00:00. The queries are the exact same when run in SSMS and in Grafana.
    for it to show “09/14/2021 9:00:00” instead of “09/14/2021 04:00:00”
    Here is the query for getting the datetime format run in both SSMS and in Grafana:
    CONVERT(DATETIME, FORMAT(CONVERT(DATETIME, WashDate, 102), 'MM/dd/yyyy HH tt'), 102) as 'time'
    No
    I found no results online.
I fixed it. I needed to change my timezone if anyone was wondering.
