Define timeout for Prometheus queries in Grafana
    Grafana 8.5.3 deployed pm k8s with Promtheus-stack helm chart.
    Increase the timeout of promtheus quries
    we increased the timeout in prometheus datasource configuration and in addition in grafana.ini we increased the dataproxy timeout ,
    but the timeout still 30s
  • What happened?
    still getting time out after 30s
    timeout to be changed according to when we defined (bigger than 30s)
 grafana.ini:
    dataproxy:
      logging: true
      timeout: 900
      keep_alive_seconds: 900
      dialTimeout: 900
      tls_handshake_timeout_seconds: 900
  additionalDataSources:
      - name: Prometheus
        type: prometheus
        url: http://prometheus-stack-kube-prom-prometheus.monitoring:9090/
        access: proxy
        isDefault: true
        jsonData:
          timeInterval: 30s
          queryTimeout: 900s
          manageAlerts: false
Grafana UI error:
