We have some defunct data sources where the plugin no longer exists, and they are dead. Is there way in the GUI to delete a datasource? Or possibly via CLI?
Click on the Configuration gearwheel, select Data Sources, and you should get a
list of the data sources which are configured.
Click on one, and there should be a “delete” button at the bottom.
If not, let us know which version of Grafana you’re using and what you find
instead of the above.
Antony.
Same question as the original above. We DO have the delete button at the bottom but it’s unclickable. Why would that be when our new default data source is current and in use?
I am stuck at the same screen. It continues to load and I’'m not able to delete the data source
And when eventually it times out and gives me the option to delete, there is an error and the delete is unsuccessful
same issue here. and was not posible to delete from cli.
cat /etc/grafana/provisioning/datasources/ansible.yml
apiVersion: 1
deleteDatasources:
- name: Prometheusssdss
will delete the datasource.
To anyone having this problem now. To delete a Data Source from the GUI do the following:
Access your dashboard through eg: http://grafana.staged-by-discourse.com
After you login click on the gear icon in the bottom left corner >> Configuration >> Data Sources and the existing data sources will appear
Click on the one you’d like to delete
Scroll down and click on delete
