Hi, have some text values in zabbix it returns 0 or 1 (some reg key from windows OS).
But cannot get this data in grafana, i meean 0 or 1, that is why cannot build dashboard.
What is the reason of this behavior?
Very much thank you!
You can you use stat panel, make sure you remove any aggregation (mean, total), in the panel configuration choose to display First instead of the default mean and in values droplist choose your metric.
Good Luck
Hi, thank you for your response.
But it’s not working for me. It;s strange, because i’ve done it before and it was fine. But there was a difference in config (Zabbix 4.0 and Grafana 6.x) now i have Z. 5.v and Grafana 7.x! I’v selected the single stat, First in calc. but no option. Cannot understand. Even the value mapping not working because no data from Z. Very strange
Screenshot_8|690x246
Can you specify exact version of grafana, try Stat panel not single stat.
Good Luck
If I understand well, the problem is not in the display, it’s on the data which is not received right ?
Correct. And i cannot understand why. There are a lot of other data and everything is fine. The problem is only with this item.
