I’ve an issue with the version showed on raintank plugin and the real ones installed on my system.
On the dashboard I see 1.0.7 and the ad that indicates that there is a updated version, but with the terminal command “grafana-cli plugins ls” I can see that the real installed ones is the raintank-worldping-app-1.2.3
Maybe it’s not important but I’ve problems running raintank locally and perhaps it’s the solution…
Thanks in advance
Thanks for your answer Danielle but, on the console, the grafana-cli command shows the 1.2.3 raintank app version.
But on the frontend I can see the 1.0.2. and the “Problem! Unexpected error” on the right corner
Is any way to uninstall completely the worldping-raintank on the Grafana Frontend to ensure, when reinstall, it’s getting the correct version of the plugin?
