Display metric label as Stat panel value
Hi folks
Working to update an old Grafana dashboard to be compatible with v7. There are a few “singlestat” panels which show a single prometheus label as the value - which is apparently not supported in v7.
This Github ticket is apparently the same problem and is closed as fixed, but I cannot see how to make this work.
The actual metric looks like:
# HELP artifactory_system_license License type and expiry as labels, seconds to expiration as value
# TYPE artifactory_system_license gauge
artifactory_system_license{expires="Dec 31, 2020",licensed_to="ACME Corp",type="enterprise plus"} 2.547315e+07
This old post has a working example of what I want from Grafana v5, but the thread concludes with something slightly different (displaying a label as panel title)
https://localhost:3000/t/extract-labels-values-from-prometheus-metrics/2087/6
